Problems with Timestamp between UC and TUI
oz
Has anyone had the problem with different times between htuser and root as this seems to affect the timestamp. It seems that htuser time stamps the email of the voicemail but the root time stamps the TUI message. I have tried a number of Linux based commands to rectify the difference , but there seems to be a constant 8 hour difference between the two times even though they are configured in the same timezone.
iourid
What version of OTUC do you use?
I had a problem in 3.7.173 when UM TUI read out date of time stamp of voicemessage wrong, e.g.if an voicemail is received 1:30 pm today (i.e. 13:30) and user checks it at 4pm, TUI says "received today at 13 hour 30 minute", if check it at 8pm, TUI says "received yesterday at 13 hour 30 minute".. I have got hot fix for this and believe it is fixed in 174A.
Don't know if you have the same problem, just wanted to share.
Thanks much
Thanks much
oz
