massege on digital sets display "call you installer&quo
sappe
Post by sappe »
i maintain a pabx (alcatel 4400) but knows very little about it. recently i had some problem with with the PABX, the problem was, some sets are being automatically transfered (immediate transfer) to other sets without a knowledge of the user so i restored the system with new chorus and one month old back up. now there are someother problems. sometimes there is a massege on all the digital sets saying "call your installer", this massege appers sometimes not always...any advice on this
sappe
Post by sappe »
one more thing, the digital sets works fine without any problem, but nothing is seen on display except the massege on display "call your installer"
oldboy
Post by oldboy »
It means you have an invaild OPS file, in the OPS file you have a Hard key or a CPU ID and you will find this is incorrect to what your CPU has, call your installer will happen after a panic flag has been set for longer than 4 hours. you can run sprecover to fix the display but this will only work for 3 tries and then you need to reset the box until you get your OPS fixed.
Return to “GENERAL”
