No more than 2 external caller can call into the conf centre
azhar
Post by azhar »
Hello
I have an issue with one of our client's teamwork server.
Consider the e.g. below.
The system has 6 audio ports.
User A creates a reservationless conference.
The access codes are sent to callers B, C, D, E and F.
Callers B and C get into the conference centre OK, where caller A is already. When caller D calls, he gets a busy tone. Same for E and F.
Now User A is advised of this by D, E or F, e.g. by email. While B and C are still in the conference, A calls D, E and F and these connect OK.
So if A makes the call from the teamwork window, the calls connect. However, then the external callers call in, they get a busy tone. Why?
I have checked the audio ports allocation in the 'Configuration->System Options' page and in the 'Provisioning-> Organisation-> settings' page, and they are all allocated the correct amount of ports. This is a reservationless conf so the number of port is not limited.
Can anyone tell me why the external callers cannot get in?
regards,
Az
salami
Post by salami »
Hi Azhar,
i have the same problem. may i know which realease you are using?
azhar
Post by azhar »
Its release 7.1.4b4033.
Do you have any solutions at the moment?
regards,
Az
Can you post SIP logs from OXE and TW for those calls?
JoelO
Post by JoelO »
Under Configuration>System Options there are some audio port limits that can be enabled, maybe they are turned on?
azhar
Post by azhar »
Hello
We managed to find what the issue was. The client had DASS lines and the DDIs were limited to 2 channels at a time. We have recommended that they move to PRA circuits. We are awaiting this and hopefully, this should be the end of it.
cheers
Az
Return to “My Teamwork (ex-eDial)”
