OXO card rejected
louisj
OXO card rejected
Post by louisj »
Hi guys
Please assist me, I've got an OXO with a Mix 244, Mix 484, APA4, SLI 8 and a SLI 16. The Mix 244 card is always shown as present/rejected. My licensing allows for the mix boards. Any ideas why this happens?
Louis
Konstantinos.E
Post by Konstantinos.E »
Hello
fisrt make a backup!
make a cold reset and restore the configuration!!if the problem is not solved do lola and put the licence and again restore!if not solved hardware problem..
kevinm
Post by kevinm »
What size rack do you have? and what is the card layout?
enio.eltz
Post by enio.eltz »
MIX 244 can be in a wrong slot.
Rack 1 - any slot.
Rack 2 - any slot.
Rack 3 - only slots 1,2,3 and 4.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
B channel license for mixed board present?
Return to “System”
