Dear All.
I want IP touch phone 4038EE firmware upgrade.
because 2 Phones are firmware version is low version another IP touch phone.
I search the firmware method or tool is nothing.
Whose is that known firmware upgrade ?
I want upgrade IP touch phone.
pls reply the answer
thanks
IP touch Phone Firmware Upgrade
Re: IP touch Phone Firmware Upgrade
command "downstat t" show not upgraded sets?
What managed in Phone feature COS for this sets - Download policy and Download start (for delayed).
thkim81
thanks vad
but I want IP touch phone hardware flash memory version upgrade.
ippstat d 7012
Firmware version Data : 4.20.60
This Firmware version upgrade.
How Do i upgrade firmware?
ippstat d 7012
As I understand - IP Touch will be upgraded automatically (from PBX depends of release)
I1.605.14e - 4.20.60
I1.605.16c - 4.20.70
I1.605.21 - 4.21.00
Just commect set to PBX with right binaries.
I1.605.21 - 4.21.00
thkim81
Yes.. but 2 IP touch phone is status bad
exactly tell you, I confiue setting IP 2 Phone.
and Phone is reset. 1/5 2/5 3/5 ...
but Normal status is 4/5 but Phone display is invalid data binary and bad file content and 5/5 status gone.
and After DN is enter the phone. I saw the LCD Status . it's status bad wrote at LCD.
Another some phone are same status(bad), but starange thing is some phone are bad status phone changed Normal status phone during few days.
today is 1 phone change bad -> normal.
How do I confirm this problem to solution situation ?
I just knew bad status firmware ->4.20.60 normal status firmware -> 4.20.70
alabastine
Look at this topic :Board index ‹ VOICE - Common topics for Crystal / Common hardware ‹ Bugs & Security issue /Problem download binary to 4038
As you can see there are more problems with the Ip touch phones
