/dev/crashdump
mokhtar14
/dev/crashdump
Post by mokhtar14 »
hi sir
I have problem in my standby CPU , always I find there is a dump on /dev/crashdump
but in role cpus I didn't find this , please can you help me
ACFE OXE R10
Re: /dev/crashdump
Was some problem with your CPU (information - RAM dump stored like crashdump file.
You will have this notification until you delete this file.
To save the crashdump, if you want to open a case and send it to Alcatel France, do dumpsave -r -o path/to/file
then gzip -9 path/to/file
to remove the crashdump , under root , do dumpsave -w
mokhtar14
Re: /dev/crashdump
Post by mokhtar14 »
hi sir
Thanks for your help
ACFE OXE R10
Return to “Linux tricks”
