could not able to get tickets as on date on enterprie.
penny
using 4760 software, i could not able to get tickets as on date. the syncronisation on nmc and node done successfully. after that i done partial syncronising on accounting counters(ptp).then in log it showing loader not active. next message syncronising done successfully. using adminnmc i taken reports using duration by set and directory entry. these definitions copied from accunting-->predefined definitons(querry tool).in date flter, i gave date>=11/1/04 and date<=2/22/05. but i could not able to get records as on date.
penny
could not able to get records using cost by set option
i reconfigure the 4760 software. now i can get records as on date. i can able to get records using duration by set option. but unable to get proper records by cost by set option. what may be the problem? the records exists in pbx. but using cost by set i unable to get it.
RuSt
