4645 VM Auto Attendant can not be reached from DID
giovanni.attolini
Post by giovanni.attolini »
I had a VM AA working ok but after a OXE reboot it stop to working. I verified that is only with external calls, if an user call the associated internal number he can hear the menu. When we call from DID we get busy tone.
I tried to restart shelf 18 and the virtual GPA without success. Any sugestion?
Sent from my iPad using Tapatalk HD
Giovanni A. Attolini
giovanni.attolini
Re: 4645 VM Auto Attendant can not be reached from DID
Solved after OXE CS reboot.
thanks
Hehe magic step
Sent from my XPeria Z
giovanni.attolini
Reboot, solving problems since Eniac.
alex
Post by alex »
My favorite: "If nothing helps - try shutdown"
giovanni.attolini
For information, happened again and rebooting not solved my problem this time, so I updated to j260329b and solved the problem.
CTRL-ALT-DEL , lol
Return to “Voicemail (46x5)”
