I'm having an issue where one switch, in a stack of 3, seems to randomly reboot. This happens every few weeks and is not predictable. A few weeks ago I upgraded the firmware to OS6250 AOS 6.6.3.509 R01 but doesn't seem to have fixed the problem.
I've been told the power supply has been replaced in the past so it doesn't seem to be a power issue.
These are the logs I can see.
Does anyone have any idea what could be causing this or what I can do to resolve it?
TUE JAN 07 11:20:54 2014 LLDP warning lldpProcessMgmtAddrTLV: Mgmt Addr TLV has unsupported AFN 6
TUE JAN 07 11:20:49 2014 LLDP warning lldpProcessMgmtAddrTLV: Mgmt Addr TLV has unsupported AFN 6
TUE JAN 07 11:20:36 2014 LLDP warning lldpProcessMgmtAddrTLV: Mgmt Addr TLV has unsupported AFN 6
TUE JAN 07 11:20:35 2014 LLDP warning lldpProcessMgmtAddrTLV: Mgmt Addr TLV has unsupported AFN 6
TUE JAN 07 11:20:33 2014 LLDP warning lldpProcessMgmtAddrTLV: Mgmt Addr TLV has unsupported AFN 6
TUE JAN 07 11:20:32 2014 LLDP warning lldpProcessMgmtAddrTLV: Mgmt Addr TLV has unsupported AFN 6
TUE JAN 07 11:20:31 2014 LLDP warning lldpProcessMgmtAddrTLV: Mgmt Addr TLV has unsupported AFN 6
TUE JAN 07 11:20:30 2014 LLDP warning lldpProcessMgmtAddrTLV: Mgmt Addr TLV has unsupported AFN 6
TUE JAN 07 11:20:29 2014 LLDP warning lldpProcessMgmtAddrTLV: Mgmt Addr TLV has unsupported AFN 6
TUE JAN 07 11:20:28 2014 LLDP warning lldpProcessMgmtAddrTLV: Mgmt Addr TLV has unsupported AFN 6
TUE JAN 07 11:20:27 2014 LLDP warning lldpProcessMgmtAddrTLV: Mgmt Addr TLV has unsupported AFN 6
TUE JAN 07 11:20:26 2014 LLDP warning lldpProcessMgmtAddrTLV: Mgmt Addr TLV has unsupported AFN 6
TUE JAN 07 11:19:57 2014 HSM-CHASSIS warning == HSM == NI [2] Request NI monitoring Start..
TUE JAN 07 11:19:57 2014 HSM-CHASSIS warning == HSM == RECEIVED NI_READY [2] from ESMDRV ...
TUE JAN 07 11:18:30 2014 HSM-CHASSIS warning == HSM == NI [3] Request NI monitoring Start..
TUE JAN 07 11:18:30 2014 HSM-CHASSIS warning == HSM == NI [1] Request NI monitoring Start..
TUE JAN 07 11:18:30 2014 HSM-CHASSIS warning == HSM == RECEIVED NI_READY [1] from ESMDRV ...
TUE JAN 07 11:18:29 2014 HSM-CHASSIS warning == HSM == RECEIVED NI_READY [3] from ESMDRV ...
TUE JAN 07 11:18:28 2014 DHLAA error Csnmp(2332):The dynamic FSM update contains NULL
TUE JAN 07 11:18:36 2014 SYSTEM alert i2cReadPartialSFPSep: sfpModuleId 26 i2cRandomRead ERROR retry 5
TUE JAN 07 11:18:36 2014 SYSTEM alert i2cReadPartialSFPSep: sfpModuleId 26 i2cRandomRead ERROR retry 4
TUE JAN 07 11:18:36 2014 SYSTEM alert i2cReadPartialSFPSep: sfpModuleId 26 i2cRandomRead ERROR retry 3
TUE JAN 07 11:18:36 2014 SYSTEM alert i2cReadPartialSFPSep: sfpModuleId 26 i2cRandomRead ERROR retry 2
TUE JAN 07 11:18:36 2014 SYSTEM alert i2cReadPartialSFPSep: sfpModuleId 26 i2cRandomRead ERROR retry 1
TUE JAN 07 11:18:35 2014 CSM-CHASSIS alert == CSM == loading iprm.lnk from /flash/working/KFbase.img
TUE JAN 07 11:18:34 2014 CSM-CHASSIS alert == CSM == P9_3 - Takoever Started, asking ConfigMgr to Parsing boot.cfg ...
TUE JAN 07 11:18:34 2014 CSM-CHASSIS alert == CSM == CSM_P9_3 - CS_DEFAULT_CONSOLE_TERMINATE has sent to SesMgr
