Hi guys,
I,m having trouble loging on to 4760 as adminnmc or any other account.
When I try to logon I get a message saying: logon unsucsesfull. I have done a reset of the pc, reinstalled Java and 4760 but with no result.
Does anybody have any idea?
It's 4760 release 2.01.16.00 on a w2000 sp 4 machine
thanx
unable to logon as adminnmc
la_toupie
IceMan_DUP
Yes, I use the same password as in the setup but it's not working.....
I'm using 476o client but the server is running on the same pc.
In the connect to serverbox in the login prompt is the right name.
Is there a hidden username and password that you can use when you lost your normal password or something like that?
Maybe something in the registry I can change?
la_toupie
Was there an another installation of 4760 on this server ? I've the impression that there a file .ini which conserve the old password...
Perhaps, there's a way to change the password but idn't know it
Otherwise, the better is to uninstall (with the procedure), delete the registery's keys...
Good luck
Good luck
IceMan_DUP
IceMan_DUP
