can someone help me to use MGR?
freefalling
Post by freefalling »
I am the new to Alcatel OXE. Before I could use Neterm to log in and create the new number, but now my colleague blocks "MGR", when type MGR, just show "-bash", how to use 'MGR" again? in OMNIVISTA 4670 to open 'MGR" or ? thanks for your sincerely reply .
aflores
Re: can someone help me to use MGR?
Post by aflores »
Hello, have you tríes tu use just telnet fron your pc instead of neterm?
what do you mean that your college block mgr?
AFlores
freefalling
We use System Voice Guide:V5.2, when type mgr in Netrerm or Telnet, they just show "-bash:mgr comment not found",
but you can find "MGR" comment in Data Base, please see the attachment ~
Can someone help me how to solve this problem? there is really inconvinience not to use "MGR" ?
or how to resctructure "MGR" comments during the unix instruments?
really thanks a lot ~
best regards
kURT
You are running mgr command under mtcl account?
freefalling
Yes, I am running MGR under the mtcl. Actually I could modify when run MGR under the mtcl, but not recently. My colleague removed or block MGR to use Unix or others instruments ? If you know how to recovery the MGR, please let me know. Really Thanks for you do me a favor.
Best regards,
Kurt
freefalling wrote:Yes, I am running MGR under the mtcl. Actually I could modify when run MGR under the mtcl, but not recently. My colleague removed or block MGR to use Unix or others instruments ? If you know how to recovery the MGR, please let me know. Really Thanks for you do me a favor.
Best regards,
Kurt
We cannot guess what your colleague did. Maybe you can check looking into /var/log/shell.log
There you can find what he did (if he did not manipulate also this file...).
freefalling
Hello~
I found my colleague changes the name, finally it's sucessful ~ thanks everyone.
best regards
Kurt
Return to “4760”
