Hello ALL,
I got trap messages via OV:
Slot X Port X port-level, RX:crossedAbove Threshold, RXTX: noChange
Slot X Port X port-level, RX:crossedBelow Threshold, RXTX: noChange
I did not find detail information about these traps.
Could hint, where I can find thresholds for ports ?
I found only threshold for system (entire device).
HealthMonPortTrap
devnull
Re: HealthMonPortTrap
There is (afaik) no port specific threshold.
Even while you can configure something for ports using Omnivista it still will only change the global threshold.
kabalin
Hey. You've found the answer? I have the same problem.strelok wrote:Hello ALL,
The answer is one post above
deep+kumar1102
I also get the same issues while my threshold is set to 80 , You can check that with the below command
show health configuration
i also check in OV that mximum value it achieves is 30 only , i have gone through for 24 hours data , but tsill i am getting alarm in OV.
deep+kumar1102
kabalin wrote: ↑01 Nov 2016 12:41Hey. You've found the answer? I have the same problem.strelok wrote:Hello ALL,
Have you found the answer now?//
