AHL format configuration file
ciantark
Post by ciantark »
I am trying to change the format of the tickets send by Alcatel when check in and check out using V24 reduced mode. Is there a way from Linux/config file to continue changing the format?
tgn
Re: AHL format configuration file
Post by tgn »
the format is called smdr. it is specified by alcatel. the only choice is between 'normal' and 'extended' format (in oxe mgr under application/hotel). if you are an alcatel-lucent application partner you can ask them directly about the format details.
regards...
ciantark
Post by ciantark »
Return to “Hotel mode”
