Real Useful Commands to help you in Troubleshoots
dennooze
Post by dennooze »
For those of you who are in troubleshooting areas, you should know the commands stated below here by hard as it will come in handy when you are tracking some weird problems and also it helps you narrow down the possibilities.
1) trkstat -r (trunk group number)
    - checking the trunk lines status as well as errors
2) cplstat (shelf number) (board address)
    - Checking the card's status
3) listerm ([color=#FF0000]shelf number[/color]) (board address)
    - provides you with a list of circuits that's available within a card and also the circuits' status
4) termstat d (extension number)
    - checking extensions' status and others like forward and related information
I have more to add in future. Kinda busy now got to go off.
**Thanks for the correction due to i'm unable to reedit it with the choopy connection I had at that time.**
knightr1der
Re: Real Useful Commands to help you in Troubleshoots
Post by knightr1der »
dennooze wrote:For those of you who are in troubleshooting areas, you should know the commands stated below here by hard as it will come in handy when you are tracking some weird problems and also it helps you narrow down the possibilities.
2) cplstat (node number) (board address)
3) listerm (node number) (board address)
10/10 for trying - but I will correct your mistakes as below;
2) cplstat (SHELF number) (board address)
3) listerm (SHELF number) (board address)
dennooze
Post by dennooze »
Thanks for correcting me, I try to follow the terms used by the Alcatel System. In layman terms, that should be the correct ones. I had quite a choppy connections here due to some power outage at the exchange, I tried to edit my post but none of them can be submitted.
One more command I would like to add:-
1) config all (listing of all the cards available in your system and status)
2) downstat (downtime status of the card in the system if you have any)
These commands is a must to remember in our head as troubleshooter as without them you will have a hard time tracing them.
Return to “Usefull commands”
