Stuck in miniboot and all LED port on
mursid
Post by mursid »
Hi all,
I need advise, my 6250p24 and 6250-24 got stuck at miniboot command prompt and all LED for port are on.
kindly advise
thanks,
Mursid
slixxboy
Re: Stuck in miniboot and all LED port on
Post by slixxboy »
what is your microcode?
-> show microcode
devnull
Post by devnull »
Can you post the boot-output (attach it here)
ist you can enter miniboot i would try to do a newfs to delete the flash and than reinstall the firmware using USB Stick or xModem.
If you can't do that rma the switches.
@slixxboy: Afaik there are no "show" commands in miniboot.
mursid
Post by mursid »
Hi devnull,
I attached the sysNewfs command as per your request.
Kindly advise
regards,
Mursid
Have you tried the next point from devnull: reinstall firmware?
Search the forum for similar posts f.e. viewtopic.php?f=329&t=22616&p=83307&hil ... ery#p83307
Return to “OmniSwitch 6250”
