Caller ID on 4039
robbo22311
Caller ID on 4039
IS it possible to get caller ID on the 4039 and if so how to enable it thanks.
L_lefante
Re: Caller ID on 4039
Yes, it is possible.
Please give more specification about the system and about the type of external lines to give you more details.
robbo22311
I'm sorry i don't know much about the system/ external lines it was all set-up by a previous worker and now the boss asked me if it would be
possible to set it up with caller id. I was looking in the manual on page 10 (Enable The CLASS SERVICE) but when i get to Terminal there's no Class Service to select not sure if its even the right way.
seems to be OxO
First of all and depending on trunk type , you external line should activated with clip(CID) at carrier level , check this first
ok and system is oxe or oxo , external line is analog, isdn etc..?
you poste at oxe commonH.
if analog line using APA BOARDS
check clip parameters
manag ext call back translator
─Consult/Modify: Ext.Callback Translation───────────┐
│ Instance (reserved) : 1 │
│ Basic Number : DEF │
│ Nb.Digits To Be Removed : 0 │
│ Digits To Add : 0 │
good grounding ?
good grounding ?
