Hi Everyone,
I need to upgrade AOS on 6900.
Currently i can login to switch via local password.
Need to know how can i config the switch to be tftp or ftp server ?
Also can i use same local password for ftp also?
Mike
Enabling FTP ot TFTP on 6900
devnull
Re: Enabling FTP ot TFTP on 6900
aaa authentication ftp local
-> Enables you to login to the switch using ftp
afaik SCP is also possible.
Don't know whether tftp is supported
tftp is supported. But switch is the tftp clients. So you need to login at cli to use the tftp commands. For SCP you need a login with ssh access.
mike18
Need to confirm with FTP switch act as FTP server right?devnull wrote:aaa authentication ftp local
Also how can I mark this answer as correct?
Mike
We don't have Answered system... No competition
Hi mike18,
if the switch acts as ftp-server than you need
you have to use your pc as ftp client (f.e. filezilla or WS-FTP).
If the switch acts as ftp or tftp client than you don't need specific rights for it (you only need cli access for your put/get commands).
there is no chance to mark the answers as corrcet
But we are happy about a lot of
