On a customers site running the latest version of 3.1 and using the latest release of Pimp 5.1 (build 369) I can sucessfully install and use the app on my laptop, however if I attempt to install it on any other PC (both the customers and some of my co workers) the install fails just after the point where I tell the wizard that I wish to use a multimedia based connection.
The failure code is "Wizard failed to find all of the VoIP parameters. Multi media set can not be used (81)"
The system is running a CPU-1 with the VoIP8 board mounted on the CPU.
Just to reitterate Pimphony will work on the site but it would appear that it only works on my laptop (I have offered to sell them my laptop for a resonable price but they did not seem too keen on that
