Any way to test in trial-mode OmniVista?
stich86
Post by stich86 »
Hi guys,
i want to test OmniVista to see what it can do, but I don't find any way to make a trial.
Looks like only the OmniVista 10 (that is Cloud) seems to have a trial.
Any advice?
Thanks!
Cristek
Re: Any way to test in trial-mode OmniVista?
Post by Cristek »
To my knowledge OV2500 is still free up to 10 devices of each type.
You can download and install OV2500 from the ALE BP and request a free license from your ALE representative.
You'll be able to use 10 APs, 10 Switches and 10 3rd party devices in it.
stich86
Post by stich86 »
What do you mean for each device of same type?
For instance, if I have a 6560P48 and a P24 is considered same type or not?
Cristek
Post by Cristek »
There are 3 types (categories): APs, switches, and 3rd party.
As far as I know, the free license has 10 of each!
