I have a customer with OXE R. 8.0-g1302-6e. The customer uses Siemens SL1 and Ericsoon DT290. When it receives a external phone the display of the Dect phones is empty. If I set a name in the trunk group, than in the dect phone appears the trunk group name.
How can I show the calling number in the display on incoming calls?
Thanks!
Empty display on external incoming call
Re: Empty display on external incoming call
This question discussed many times.
First - check with t3 command - calling number present in SETUP message or not.
If present - manage Ext. callback translation.
michele.romano
I have cheked with t3 and the external number appears in the set up.
I have managed the ext. callback translation in this way:
┌─Review/Modify: Ext.Callback Translation────────────┐
│ Node Number (reserved) : 1
│ Instance (reserved) : 1
│ Basic Number : 3
│ No.Digits To Be Removed : 0
│ Digits To Add : 0
Thanks!
michele
│ Basic Number : 3
│ Digits To Add : 0
Thanks!
michele
michele.romano
After a reeboot the customer is able to see the external calling number in the display of dect.
Thanks!!
Thanks!!
- tot3nkopf
Instead of defining all first digits of external numbers try to use:
Basic number: DEF
Just a tip.
Regards.
Basic number: DEF
Just a tip.
Regards.
torrentula
There should be a DEF by default... no pun intended. At least in the US it is.
- tot3nkopf
In Romania there's nothing configured by default in Ext callback translator.
Regards.
Regards.
